Set dryer on cotton senso program time shows 206 mins The dryer runs on for approx 35 mins cuts out then reverts back to start time? No fault code showing
If you set off on timed 30 mins works ok?
Is this a sensing issue or pcb? have changed front temp probe 154166.
Before changing this would only run for 15 mins?
Maybe element is beginning to fail and gradually leaking more current to earth as it is on for longer periods. It’s often such things which lead to jumpy electronics.
Mike.
IIRC , If you stop these dryers during a cycle , on restarting them , the time will revert back to its initial start time before re-calculating the new drying time after start up……so , i’d be looking at the door lock or a power supply problem .
