My dryer continually ends prematurely after a few minutes of running with
any program setting and aborts to the anti-crease/end lit on the front panel.
The dryer is heating/turning etc but seems to only run for a few minutes.
I have thoroughly cleaned all the filters including the condenser etc.
I would welcome any advice or suggestions towards a fix.
Re: Bosch WTE86304GB Condenser Dryer goes to anti crease/end
Thanks for your reply.
Put in damp clothes approx 3-4kg and tried various program settings.
After 2/3 mins the machine goes to time zero with the anti-crease/end led lit up.
No other lights.
Will try without any clothes to see what happens….
it wont work without any in as there sensors in the dryer than detect humidity, all that will happen is it will shut off after a minute because it assumes the clothes are dry.
I see there has been no answer to this question. I too have a Bosch Clasixx Condenser dryer, less than 2 years old and for the last 6 months it has refused to run properly. Regardless of what is in it, it immediately goes to the anti-crease/end cycle.
