Bosch Wte8630sgb/03
  • #92549
    dash
    Hi all
    Hope somebody can maybe help before im forced to replace my trusty bosch condensor dryer.
    Its about 10 years old so it does not owe me nothing as its had a hard life
    It is starting and heating but the problem im having is it just stops there is no fault code on the screen it sometimes goes for 2 mins other times 20min.
    All i can see is the start button is flashing if i switch it off and back on it restarts but stops again
    Filter is clean and the pump is pumping to the drawer.
    Any ideas before im forced to replace it?
    Many thanks in advance
    #451559
    Re: Bosch Wte8630sgb/03
    most machines have an option to run a timed programme instead of auto
    try a timed prog and see if it does the same
    dash
    Many thanks for taking the time to reply to me Dave ,
    Put it on for a 40min timed programme and it stopped after 3min and the time resets back up to 40min again
    #451561
    got all the makings of an electronic board fault
    unless any other member has other ideas
    if so price of board makes repair no viable
    you could ask http://www.qer.biz/servReps.htm
    they may have a fix for it
    dash
    Cheers for that just back in from the shed where i have the dryer.
    Seeing as you said it might be a board problem i removed the top cover and got out the hoover and vacuumed all the dust and crap off the cables and top of drum.
    Then i pushed on every connector on the board that i could see and retried it
    Success it appears to be working have a load of washing on now so it kept going now.
    Hopefully it works and if it does not i think it might be a bad joint on the pcb.
    Many thanks for the replies and guidance
    Gar
