Bosch WTE8630SGB T/DRYER
  • #71562
    mackos
    Hi Guys Got to go look at Bosch condenser tumble dryer later in the week. Customer says you put the clothes in, it then decides how long the prog is & displays the time & off it goes after about 3 mins it switches off & the display goes blank. No error code coming up. Every time you put it on this is what happens. Any ideas.Thanks Mack.
    #381505
    Re: Bosch WTE8630SGB T/DRYER
    Bunged up with fluff. Time for a good clean out!
    #381506
    mackos
    Hi Martin just went & cleaned it all out not that bad really.the display does seem to have a mind of its own sometimes.put it on a cycle empty it came up with 1hr 20mins or something heated & tumbled ok then after about 5 mins counted down to 1 min on display(presumably the humidity sensors working ok) then finished normally.after the cust had done a wash & put damp clothes in same as b4 after initially working ok for 3 mins the display goes blank & it switches off. I asked them to put it on the preset timed program that doesn’t work either.Is there a known problem with the board or selector switch. Thanks Mack.
