Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › BOSCH WTEB4102GB/03
- This topic has 7 replies, 3 voices, and was last updated 12 years, 8 months ago by
alyp.
August 11, 2013 at 11:56 am #76616
alyp
ParticipantANY HELP PLEASE ? My dryer is drying but not condensing into the water container so steam is just coming out into the room – have cleaned the pump and checked the pipes -all clear . Have poured water into the pump tray and that goes straight upto the container . Any ideas gratefully accepted
August 11, 2013 at 1:13 pm #398930Martin
ParticipantRe: BOSCH WTEB4102GB/03
The base tray under the condenser matrix to the pump chamber must be blocked. Hence no water from it is getting to the pump chamber section.
August 11, 2013 at 1:15 pm #398931alyp
Checked that too – its a mystery
August 11, 2013 at 1:31 pm #398932Andy jones
Have you checked all the seals, door seal, condenser seal, backplate seal etc. after all if its drying it must be escaping somewhere
Sent from my iPad using Tapatalk HDAugust 11, 2013 at 1:37 pm #398933alyp
thanks for the reply – yes its drying fine but the hot steam is coming out of everywhere apart from the water container ! is there a fan or something to check I thought it would just be a matter of cleaning out fluff from hoses and the pump – the floor beneath the machine is dry too the kitchen is just full of steam
August 11, 2013 at 1:42 pm #398934Andy jones
There are fans but I would have though if they where blocked it wouldn’t dry. We have a Siemens one very similar and if I don’t clean the door seal and around the door bowl after every couple of time I get a similar problem
Sent from my iPad using Tapatalk HDAugust 11, 2013 at 1:55 pm #398935alyp
Thanks again for the reply but just had a quick check and the seals seem ok just don’t understand what it can be – we have cleaned everything as people have advised but no result .It is really odd as it is drying well and in the normal time it normally takes just no water going upto the container
August 15, 2013 at 10:35 pm #398936alyp
Hello
I still have the same problem – any one have any more ideas please ? the steam is coming out of the side and top panels and steam instead of water going into the container drawer -
