bosch WTL 5400 Con-dryer
  • #25316
    rocker
    machine was working ok, it stopped and started buzzing,customer cleaned condenser as it was was blocked.
    called today timer buzzing as if telling us end of programe, won’t reset
    to allow new programe, cant any one help please.
    John.
    #205357
    gegsy
    Re: bosch WTL 5400 Con-dryer
    Can you supply full model number and also say if any lamps are flashing 😀
    Cheers
    rocker
    Re: bosch WTL 5400/GB11 Con-dryer
    Greg, . Model WTL5400/GB/11 cupboard dry light flashing and bleeping .customer thinks its about 10 yrs old.
    #205359
    gegsy
    Im guessing its this WTL5400/GB/01, as I cannot see an 11 index.
    The fault you are getting is indicating a a fault with the (R2) NTC, which is situated above the heater.
    This NTC looks at the temp of the air feeding the drum. Check connections etc before ordering.
    I cannot see this as spare, so it may come with heater :con:
    rocker
    gegsy wrote:Hi
    Thanks Greg,
    will check this out…
    Cheers
    John.
    #205361
    Kentish
    Loose fan impellor on the back end of the motor shaft?
    Could cause a lack of air flow through the heater resulting in almost overheat situation.
