Bosch WTL 5400 GB/04 Skipping Cycle
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WTL 5400 GB/04 Skipping Cycle
  • #29325
    Turbo
    This dryer has an intermitent fault. When set on sensor dry mode it will finish to early leaving the clothes still very damp. When this happens the start light is left flashing.
    Have cleaned the drum paddles and carbon drum contacts with vinegar.
    Have run out of ideas myself, any suggestions would be great.
    Graham
    #222759
    gegsy
    Re: Bosch WTA 5400 GB/04 Skipping Cycle
    Can’t find that model, but if its a condenser dryer, have you thoroughly cleaned the condenser unit,that the vent is clear and fan is working efficiently?
    Turbo
    Re: Bosch WTL 5400 GB/04 Skipping Cycle
    Sorry Greg WTL 5400 GB/04.
    Well I did give the condenser box a clean out but I will have a closer look at the fine mesh slots where the cool air flows.
    On the intial visit the pump chamber was full of grey sludge causing the water container light to come on prematurely but that is ok now.
    If the condenser box is ok have you any other suggestions.
    Graham
    #222761
    gegsy
    In that case its worth removing r/h panel and locating uplift hose to dispenser.
    Remove both ends and make sure its clear top to bottom and also remove uplift pump and check impeller for fluff chaffing (ooer)
    HTH
    Turbo
    I cleaned the pump and pump chamber plus hoses on the first visit.
    Graham
    #222763
    gegsy
    Sorry missed that, just running stuff off quickly 😀
    Will send you some info that will help.
    Turbo
    Thanks Greg that would be great.
    Graham.
    #222765
    gegsy
    Just had a thought.
    If the appliance is under loaded, then there is a chance that there will be not enough fabric between the drum and the paddles to actually sense a load ie machine thinking clothes are dry hence the short prog 😕
    Turbo
    Interesting that.
    Thanks Graham
