Bosch WTL5500 condensing water light comes on in error
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch WTL5500 condensing water light comes on in error
  • #77693
    mike_p99
    The condensing water light on my Bosche WTL5500 comes on after aout a minuteof running despitethe tank being dry. Is there a sensor or switch somewere which can be fixedto correct this?
    #403060
    Re: Bosch WTL5500 condensing water light comes on in error
    Check the pump chamber is clear and that the pump hose (to the water container) isn’t blocked. A blockage THE most likely reason for the fault.
    #403061
    mike_p99
    ok – have disconnected the hose at the top & can blow through it, so that doesn’t seem to be blocked. I have tracked down where the pump is, but can’t work out how to get it out. Also, how would I check whether it’s working or not?
    #403062
    mike_p99 wrote: I have tracked down where the pump is, but can’t work out how to get it out. Also, how would I check whether it’s working or not?
    Access is a little restricted for sure. Take it out and clean the float chamber then pour a pint of water into the pump chamber before reassembly, turn on dryer and that pint of water should pump up into the water container. That is a simple test to ensure that the pump works AND that it’s not blocked.:D
