Has been working well for past 2 years or so but has just developed a leak. No water is being pumped through the hose that exits the rear of the appliance, its just leaking out of the bottom.
I’ve checked it with a spirit level and made sure the condenser cartridge is pushed home securely. I dont know much about these things but think its probably a problem with an internal hose or the pump – any other thoughts?
To avoid the possible expense of calling out an engineer can I remove the plate from the back of the machine to have a look or am I likely to end up causing myself more problems.
Any advice would be appreciated.
cheers
Simon
