Bosch WTL6103GB drier stops after 1 minute.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WTL6103GB drier stops after 1 minute.
  • #51070
    aqualectric
    Bosch WTL6103GB drier.
    Customer reports the drier runs for about a minute on all cycles then stops. The only exception is the 30 minute warm cycle. Any ideas what it’s likely to be ahead of a visit? It sounds to me like a sensor issue as the 30 minute is a timed cycle, but I could be wrong. After spending all last Sunday on one of these I’m not particularly fond of Bosch driers. 👿
    So any help would be appreciated!
    Thanks,
    Steve.
    #306790
    Re: Bosch WTL6103GB drier stops after 1 minute.
    Dodgy carbon brush pick up? Pump/float chamber gunged up? Pump hose to tank blocked? TOC tripped?
    #306791
    Troffy
    i had the same trouble on a Meile last week, the heater had a Bra wire jammed in it, everything ran until the heater fired up then it cut out, the Heater was shagged and i’m still trying to get one at a realistic price
    #306792
    nomadPaul
    Check that the customer is running it with a load in. Also that the load is a full one. Just drying one item or a number of ‘smallls’ can cause probs as there is inadequate contact between the drum paddles and clothes .
    Also , ask if there are any flashing led’s or fault indications.
    I’d go with Martin and check the TOC first
