Bosch WTL6106GB/07
  • #65004
    dave-m
    Have one of these which is not heating properly, it seems to sometimes put out low or medium heat, but never full heat and it just keeps going with no fault codes, (although I don’t have the codes for this machine…anyone?)
    Timed dry also puts out lower than normal heat.
    Found a blockage in the base of the pump and removed it and cleaned everything out completely but no change.
    Before I go ordering parts, does any one know what readings I should get across the heater, NTCs etc.
    Cheers
    Re: Bosch WTL6106GB/07
    dave-m wrote:Before I go ordering parts, does any one know what readings I should get across the heater, NTCs etc.
    The heater is rated at 700w and 1800w respectively.
    Heater NTC = 25k Ohm at room temp (approx)
    Front duct NTC = 10k Ohm at room temp (approx)
    #358772
    dave-m
    cheers martin.
    dave
