Bosch WTL6300GB/01
  • #23973
    ace
    Bosch condensing tumble drier WTL6300GB/01 FD8111 200384
    Called to this one, light come on in drum, set controls, push start button, nothing happens. No relays ckicking or any other noises. Presume control panel pcb, only £140 with vat, I was hoping to remove the facia panel to check for bad joints/connections on the pcb, however I could not work out how the facia panel or pcb cover is removed. Any body know how, and any suggestions on the fault.
    Thanks, Martin 😳
    #200046
    Re: Bosch WTL6300GB/01
    What about the door switch?
    #200047
    superfix
    To remove fascia, you have to prise it away with a screw driver from the underside.
    As Martin said, door lock may be faulty.
    Also had many customers call me out for similar, only to find child lock has been set :rolls: . Check the instruction manual for how to turn it off :rtm:
