This tumble drier starts to tumble back and forth three or four times then just stops with the start light flashing. I assumed the pcb was getting a wrong reading from either the drum resistance or the thermistors so checked each of these and they seemed within normal readings (damp laundry in the drum). Lo and behold having had all the connectors off and back on again the machine worked successfully for several loads which suggests there was a loose connection?
Can anyone supply the tech info on this model please….at least i might then work out exactly which connection is at fault….or has anyone had problems with intermittant thermistors on this one?
