Bosch WTL6305GB/01 no heat
  • #69614
    nelson
    I had a look at this one yesterday, the customer reported that it was running fine but no heat. I checked the element and reset thermostat and they were ok, when it was running I was getting no live feed to the element. I set the control to the 30minute warm setting and did get a live at the element for a minute or two but then it back to as it was.
    I could not see an other thermostat but I am presuming there is an exhaust stat hidden somewhere? Also was wondering about the dampness sensors, do these go faulty?
    I had a look on BSH to see if the exploded view might throw some light on where the exhaust stat might be, but the site has changed and now just lists a handful of spares for this machine.
    Any help much appreciated.
    Cheers
    #375396
    Re: Bosch WTL6305GB/01 no heat
    nelson wrote:Any help much appreciated.
    Take a look HERE
    The NTC (154166)is located in the front drum support. 🙂
    #375397
    nelson
    Ok so I have replaced the NTC located at the front of the machine and now it heats but is barely warm :rolls:
    I am wondering if the temperature limiter could be faulty http://www.bosch-home.co.uk/store/produ … ure/163297
    but I am unsure what reading I should be getting from this.
    Is this something that tends to go wrong or am I barking up the wrong tree?
    #375398
    nelson wrote:but I am unsure what reading I should be getting from this.
    25 to 30K? at room temperature.
    If you would like the service manual give me an email. 😉
