Bosch wtl6307gb/05
  • #49366
    S1MON
    Condensor dryer is causing me a headache, intital fault no heat found water had got onto the heater causing it too go down too earth. On test it was only producing a low heat, I cleaned the inside of the drum and paddles as there was a visible film around the sensor band
    carbons are fine, I have also replaced carbon by the bearing as that was not present but still does not seem too get very hot.
    Pumps fine all vents and condensor clear
    Any clues?
    #299681
    bzz67
    Re: Bosch wtl6307gb/05
    maybe a problem in the float chamber, this could have caused water getting to the element in the first place. or possible dry joint on pcb.
    #299682
    S1MON
    Cleaned the float chamber out im thinking pcb
    #299683
    S1MON
    Just an update rechecked pcb and resoldered a couple of joints and hey presto it kicked into life, first one I’ve had like this
