Bosch WTL6307GB/07 low heat problem
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch WTL6307GB/07 low heat problem
Viewing 1 post (of 1 total)
  • #76475
    Dave_talon
    I have a problem with my dryer. When used on low heat (which is the setting I use most of the time), the dryer only seems to heat up a tiny amount, run for what seems like hours and finishes with a rapidly flashing end light and a repeating sequence of 8 beeps.
    So far I’ve:
    cleaned filter and heat exchanger
    cleaned the 3 moisture sensor pads
    checked overheat stat – shows continuity
    checked heater thermistor – read around 18K at room temp, reducing when heated
    checked front thermistor – read around 10K at room temp, reducing when heated
    Checked heater element resistance – one shows 30 ohms, the other 92 ohms
    I presume I’m missing something here.
    Can anyone help me out?
    Thanks in advance,
