Bosch WTL6500 facia panel
  • #74203
    Allsorts
    How is the facia panel removed to get at the pcb on this machine without breaking plastic parts?
    George
    #390434
    Re: Bosch WTL6500 facia panel
    With the door open, if you look on the underside of the fascia you will see two slots. Insert a small screwdriver in to unclip those latches. The nease fascia forward from the bottom. Water reservoir drawer out, place a knife blade between cabinet and fascia and carefully twist blade to ease side and top away a few mm’s. Likewise along the top length of the fascia and right hand side. Twisting the blade should gently unlatch sufficient enough to remove in one!
