Re: Bosch WTL6507GB/05 bleeping
Did you have a normal load in the dryer the first time it faulted??
It has to have a reasonable damp load for the sensors to correctly detect the load. Over period of time the drum paddles get a coating of softner/conditioner, which basically gives false readings back to module.
Popular fault with symptom you describe is sensor fault in air passage below porthole p/no 154166.
The fault of anticrease flashing is a time fault which all the above are suspects 😉
