BOSCH WTR87T82GB/03 – Error E63
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BOSCH WTR87T82GB/03 – Error E63
  • #101783
    Hollytree_Technical
    Hi All
    Does anyone know what error E63 is on this please.
    Thankyou
    Jem
    #486037
    well Bosch codes are never easy but from some digging am getting hits on a communication error
    try checking connections between the boards
    kaibart
    That’s a power board fault programmed part number 10017495 expensive though £206.62
    #486039
    Hollytree_Technical
    Well just to close this one off – I don’t know for definate which component was the cause but I replaced all of the electrolytic caps and the 3 larger relays on the main board and it appears to have cured it.
    Jem
    #486040
    may have been ac ripple on dc lines
    well done
    Hollytree_Technical
    I wondered about that but the caps measured okay both on capacitance and ESR results, my suspicion is more with relay bounce (not cleanly switching) but I couldn’t prove it and the machine was too far away to make multiple trips to test either theory, either way I fitted the module back to the machine last friday, I know that they were going to be using it all weekend and have heard nothing to say that it has failed yet.
    Jem
    #486042
    kaibart
    Yes I would say a relay fault as I’ve done a few and I hear the relays clicking alot
    #486043
    DWSERV
    Definitely one or more relays fail …..couldn’t find in UK had to import on slow boat from China do ASWO stock them?
