I have one of these, heavily used in a pub, where the Filter light keeps coming on at random, but filters, hose etc all quite clear. Anyone got any info on what triggers this signal?.
Any bedtime reading anyone?.
Mike, pretty sure the electronics look at the combined signals from the two ntc’s. I’d be inclined to change the front one as I’ve had a couple causing intermittent faults recently(they’re only about a tenner). Wiz
Did you get it sorted. Ive got one that comes up with check filter after 20 mins. Replaced front and rear sensors and it runs longer but still comes up check filters.
S.
I have since had one blocked in the ducting between the condenser and rear fan where it passes the rear of the motor. Blocked condenser (cool air left to right) can also give this fault. Wiz
