Bosch WTV74105GB/13 Vented Dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WTV74105GB/13 Vented Dryer
  • #79857
    squadman
    Has anyone got a manual for this dryer that they could let me have ? Fault is dryer runs for two clockwise revolutions then stops with the Drying light and Auto/Crease/End lights flashing followed by two sets of rapid bleeps … … then does nothing.
    I have checked the two thermostats located at the rear at the side and above the heater and they are BOTH open circuit, I have bypassed these as there is live on the lower side stat and then the dryer will heat, but seems odd that both of these stats are both open and not closed ?
    The customer has had another engineer already look at the dryer who is supposed to be something of a Bosch Expert and he diagnosed a faulty Control PCB but I have my doubts about this
    Any pointers or the manual will be most welcome
    #410835
    Re: Bosch WTV74105GB/13 Vented Dryer
    some of those stats may well be ntc’s therefore will give a resistance on higher ohm scales
    also it sounds like you have a fault code when it stops
    maybe another member has a list for that dryer
