Bosch WTV74105GB/15 tries to start and then stops
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch WTV74105GB/15 tries to start and then stops
  • #92055
    TeflonDon
    I have a Bosch WTV74105GB/15 that tries to start but then stops almost immediately.
    I have checked all the airways, both heaters and the thermostats but can’t find anything wrong. Any ideas?
    Regards
    TeflonDon
    #450151
    Re: Bosch WTV74105GB/15 tries to start and then stops
    Probably the NTC sensor (part no: 00600157) at fault? Check its resistance (in KOhms) to be sure.
    #450152
    TeflonDon
    Don’t think it’s the NTC sensor as I’m measuring approximately 20kOhms
    #450153
    kaibart
    If the vent hose has a bend before a straight run of 400mm the dryer will cut out just a thought
