Bosch wvd 24460gb/04 f 18 dry side
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch wvd 24460gb/04 f 18 dry side
  • #90404
    Cras
    Hi ,there’s no power to the solenoid when drying heats ok and pumps ,wash side is fine ,presuming board fault unless anyone can suggest different please . Thanks Cras
    #444671
    Re: Bosch wvd 24460gb/04 f 18 dry side
    a lot of later machine do not start the water till its hot. assume its measuring an ntc or maybe waiting for moisture (steam)
    had a similar fault with a CDA machine but found if I set dryer and started it, then switched off at the socket, waited till all went off and turned back on. the machine started where it left off but the water was now flowing
    dave
    #444672
    Cras
    Thanks for the reply powered valve up independently which was fine ,so presume board ,customer now buying new Cras
