Bosch wvd 24520gb/01
  • #63189
    Dapman
    I wonder can anyone help.I have a bosch wvd24520gb/01 you can select program the start button flashes, when you press the button the light stays on but the machine does nothing.The door lock light flashes so i changed the interlock but it made no difference.
    Any thoughts please Dave.
    #352910
    Applianceman2010
    Re: Bosch wvd 24520gb/01
    Have you checked the filter at the front? If that’s ok it will prob be the brushes.
    #352911
    Dapman
    The pump does not make any noise,no does the machine,the door locks, but the door lock light flashes suggesting the door is open.There is no other lights flashing or alarm signals.
    Cheers Dave.
    #352912
    Dapman wrote:the door locks, but the door lock light flashes suggesting the door is open.
    Then I would suggest you check the insulation on both water and drier elements, check the brushes, open circuit valve coil etc.
    #352913
    nomadPaul
    Its the childlock symbol flashing ! Try holding the start button down for 5 seconds and i bet the key disappears and the appliance starts up ok !
