Bosch WVD24460GB
  • #95365
    rocker
    This machine is stopping at different times in cycle sometimes showing 7mins left on timer or 1 minute…I called today , I run it on a drain cycle no water in tub and took filter out of pump to check pump was running..pump started running after a while it stopped showing 1 minute….I fitted new pump to check some thing happened…I checked the heater tested ok….I believe it may be the Pcb ( bunot sure)… any advice would be welcome…..Cheers John
    #460152
    did you check heater to earth
    rocker
    checked both heaters and motor for earth leaks…none found….gave up in the end…..
