Re: Bosch WVD24460gb/05 Dryer faulty E17
The dryer fan motor and elements dont come on until about 3 mins after the dryer first starts, the fan motor starts initially then goes off quite quickly. If after about 5-7mins the dryer element aren’t heating then I would suggest you will have 240v both sides of the dryer element and the dryer will have lost its neutral on the PCB (something for which I have changed lots of the PCB’s for.)
Most times with E17 I have had to replace the PCB and inlet valve as a pair.
