Bosch WVD24520GB/07
Viewing 15 posts - 1 through 15 (of 18 total)
  • #69405
    ray.t
    Had a call to this today, machine works fine all the way through the cycle but stops just before the spin.
    The display shows 12 mins left and there are no fault codes displayed it just gets stuck at 12 mins it then unlocks the door.
    The machine is only just over 2 years old so I have told them to phone Bosch and try their luck but would like some pointers just incase they have no luck
    Cheers,
    Ray
    #374663
    Bosch WVD24520GB/07
    I wonder what icons on the display are showing when this happens? The ‘detergent overdosing’ icon perhaps?
    #374664
    ray.t
    Re: Bosch WVD24520GB/07
    Hi Martin,
    This is how it stops.
    #374665
    timdowning
    If you select spin on its own does it spin and end?
    #374666
    ray.t
    Yeah goes through a spin perfectly and finishes as it should.
    Ray
    #374667
    timdowning
    Did you see if the wash heater was open circuit or low insulation.
    #374668
    ray.t
    No but I will give it a go if you think it could be that.
    Ray
    #374669
    timdowning
    On previous / similar models of this washer dryer an open circuit wash heater used to effect the time progress bar etc, so can’t be sure but worth a try.
    #374670
    ray.t
    Thanks Tim I will go and have a look and post up what I find.
    Cheers,
    Ray
    #374671
    dave-m
    Hey guys,
    I’m reviving this thread as I’ve one with the same problem.
    Same E-Nr and it stops at 12 mins left and stays like that.
    Motor, pump, heaters, solenoids good. Meggered m/c and all good. Can’t find any wiring issues.
    Had the same problem a couple of years ago and came to the conclusion that it must be the board. Can’t remember the price but the customer would not go for it so never proved it.
    Would like to try and prove this one, is there a way of accessing stored errors?
    Has anyone solved this problem?
    Regards
    dave-m
    Anyone?
    #374673
    Mo3426
    i had a similar problem with a bosch washer dryer and it turned out to be a lump of fabric had wedged its self around the wash heater removed it through the heater hole and machine is now fine cant remember the model number but i did post about it and got no replies
    #374674
    dave-m
    Cheers for that, I’ll give it a go before I give up.
    #374675
    Mo3426 wrote:cant remember the model number but i did post about it and got no replies
    It would have been this thread Mo……..
    viewtopic.php?t=76788
    #374676
    dave-m
    I assume there was no conclusion to this snag?
    Is there a way of interrogating hidden fault codes?
