Good afternoon all,
Have an obscure fault with the above W/D.
Essentially when on a drying cycle, all is fine for between 15 & 30 minutes prior to the machine stopping and the display failing completely.
Once left for a few minutes the machine recovers, and works again until the above fault recurring.
I’ve had a look at the wiring multi plugs to the three boards, (Operating Module, Control Module & Display Module) which all appear good.
Does anyone know if the above is a known fault, and/or which module it is likely to be? (the Op’ Mod’ & Control Mod’ are both over £200.00 each!)
jonty
