Bosch WVD24520GB and Siemens WD12D520GB combi, any differenc
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WVD24520GB and Siemens WD12D520GB combi, any differenc
  • #33433
    LadFromWales85
    Hi all,
    Looking to buy my first washing machine! We live in a flat with no garden and no where to put up a line, and don’t really have the space for separate units, so are looking to get a washer dryer!
    After doing my research, it seems as though the best in the mid end market is Bosch/Siemens.
    I can get the Bosch WVD24520GB for £399 and the Siemens WD12D520GB for £439, but can’t decide which! They both look the same, aside from the different control layouts, and appear to have the same functions, but are they the same machine?
    Any help appreciated 🙂
    Thanks!
    #238682
    Re: Bosch WVD24520GB and Siemens WD12D520GB combi, any diffe
    They are both Spanish-built washer dryers and are basically the same machine. You might like to consider the WVT1260GB – same 1200 spin but a slightly lower price point.
    I thought someone said that all current BSH washer dryers are Smeg produced machines. 😕
    #238684
    Nope, punched ’em up on BSH, both Balays.
    LadFromWales85
    Thanks for the advice.
    Can find the WVT1260GB for £379.
    Any real difference aside from the larger screen/less buttons on the WVD24520GB? Unless the 1260 is available cheaper, I don’t mind paying the extra £20 for the 2450 🙂
    I’m sure I read that the Siemens models have 5 year parts warranty as standard, or am I wrong?
    Cheers!
    #238686
    gegsy
    IIRC some Siemens do ALL Bosch and Neff have 2 years.
    Don is the guru here 😉
    LadFromWales85
    If this one has a 5 year parts warranty, it may sway my decision!
    If its 2 like the Bosch, then I’ll just get that one as they appear to be identical in other respects except the fascia 🙂
    #238688
    2 years on that one by the look of it. Here’s a link to the 5 year stuff:
    http://www.siemensappliances.co.uk/?SiteMapId=1032
    No washer dryer on the list at all.
    LadFromWales85
    Awww 🙁
    Much as I’d prefer to get separates, there just isn’t the room 🙁 I know the combi’s aren’t as good performing as dryers, but anything is better than drip drying at the moment!
    If the washer can get enough water out of the garments, I could get away with just getting a clothes rack for drying…
    Is there any reason at all to get the Siemens over the Bosch? I’d prefer silver to be honest, but its almost £100 more, and I’d have to do the same with the cooker and fridge freezer, which would be a nightmare!
    #238690
    Simple answer? No!
    As pointed out earlier, they are both the same construct, so beyond a few possible programme options, there’s no advantage to the Siemens.
    Silver…….. This business is called “Whitegoods” for a reason 😀 . It’s purely down to taste – this is your first appliance, so I’m sure that you will have better things to spend £100 on.
    Good luck with it,
    LadFromWales85
    Cheers for the advice!
    Will be ordering asap then!
    Need to look in the fridge freezer section as I need one of them too! Get a Bosch also?
    #238692
    Hi LFW,
    If you’re on Anglesey you may be advised to give Deltec Electrical a shout who are based in Benllech as you can’t beat local service and, they will actually care if you do have a problem. 😉
    If you speak to Sean or Julie there they will give you good advice on what’s stocked locally.
    The only reason I mention it is that, as I’m sure you know only too well, service in outlying areas can be a bit ropey at times.
    HTH
    gegsy
    Cheers K, they can be contacted on 01248 853821 😀
    LadFromWales85
    Will be giving them a call on Monday morning!
    I’m guessing the prices will be above that of online, but with much better support? 8)
    Cheers for all the advice so far guys
