Bosch WVD24520GB F18 on drying cycle
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WVD24520GB F18 on drying cycle
  • #83227
    Bernie
    I am going to this machine tomorrow (Monday) the customer tells me he has checked that the pump/ filter is clean and the impeller turns freely. This only happens on the drying cycle, would I be right that the condenser is blocked and has to be cleaned?
    If so how difficult is it to get to and get it off?
    Thanks for any help or advise
    Bernie
    #422124
    Bernie
    Re: Bosch WVD24520GB F18 on drying cycle
    Just been to this machine and the condenser does not appear blocked to be blocked pump runs ok on both wash and drying. I think it is more electrical as at first was trying it on the low heat 15mins after 3/4 mins got F18 when I tried it on high heat 1 hour it worked for 10 mins before I stopped it tried it on the low heat for 1 hour and that worked ok before I stopped it. Once you get F18 it does not matter which drying cycle you select f18 come up straight away
    Anyone with any ideas
    Bernie
    #422125
    Andy jones
    If my memory serves right I had the same problem and replaced valve and was fine after
    #422126
    Bernie
    Thanks for the reply, I guess you mean the dryer water valve?
    Thanks again
    Bernie
