I have a Bosch WVD24520GB washer dryer. It will not complete a cycle – it says 1 minute left and just continues. I have to manually select rinse, drain and spin. Any idea what this could be?
I have checked the filter and I can see that the pump is working.
Re: Bosch WVD24520GB Washer Dryer get stuck with 1 minute le
Most likely to be the heating element gone open circuit . The appliance is waiting for the water to heater but never does. If you leave it , it normally moves on after approx 2 hour. You will need to check the resisitance of the heater which should be approx 24 – 27 ohms .
