Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › BOSCH WVD245S3GB/01 ….need an expert! starnge fault
- This topic has 7 replies, 3 voices, and was last updated 13 years, 9 months ago by
trotter.
June 14, 2012 at 10:07 am #69943
trotter
ParticipantProblems on the dryer…..Set dry prog for 30 mins gentle heat and it works perfectly.
Set dryer to auto prog….works perfectly.
Set dryer 30 mins INTENSIVE heat and it freezes with exactly 23 mins remaining! the display is stuck on 23 mins the power light is on no drum rotation no heater or water intake.Turn the dial to off position and select prog again and it starts as normal. I have replaced the dryer module – no difference. I don’t know these well enough to be confident that the main module is the fault.
June 14, 2012 at 10:30 am #376515trotter
ParticipantRe: BOSCH WVD245S3GB/01 ….need an expert! starnge fault
UPDATE!
Auto dry on intensive heat – Freezes after 7 mins (Same as manual setting on Intensive heat freezes after 7 minutes).
On test auto dry gentle heat …Works fine!
June 14, 2012 at 11:05 am #376516Martin
trotter wrote:Set dryer 30 mins INTENSIVE heat and it freezes with exactly 23 mins remaining! the display is stuck on 23 mins the power light is on no drum rotation no heater or water intake.
I’m thinking the reason for this is that to set an ‘Intensive’ drying cycle the dry time needs to be set at 40 minutes or more! (Minimum time 40 mins Maximum time 90 mins for Intensive) So I don’t think there’s a fault here. 😀
June 14, 2012 at 11:31 am #376517trotter
mmmm….will try that martin BUT….what about the auto dry fault on intensive?…Is that because it is more than 90 mins?
June 14, 2012 at 11:47 am #376518Martin
trotter wrote:mmmm….will try that martin BUT….what about the auto dry fault on intensive?…Is that because it is more than 90 mins?
I’m only guessing TBH, it is an odd fault. Mind you most folks only set it on Auto anyway as they have no clue how much time each wash will take to dry otherwise. So to a greater extent the machine is fully operative anyway!
Try setting it on Intensive for 45 mins, see what happens?
If and when it stops…what is the NTC reading? Is the element, fan and valve still reading OK also at that point?
June 14, 2012 at 11:52 am #376519trotter
just set intensive for one hour ….all okay so far not sure about readings, it takes forever going throught the tests ha ha I will try all though and report back Thanks for your support so far Martin I certainly feel a step closer.
It doesn’t give time restrictions in the user guide 🙁
June 14, 2012 at 12:00 pm #376520Martin
trotter wrote:It doesn’t give time restrictions in the user guide 🙁
How very true, it sure doesn’t. 🙁
June 14, 2012 at 7:42 pm #376521nomadPaul
It could be a blocked condensor causing an overheat condition. I had very similar probs that took a couple of visits to suss out .
