where dryer motor is held on to drum bracket keeps breaking also braket at bottom of drum rubber hose comes out and splits have put machine in other location but still does it help dal
There’s two other fixing points for the dryer air channels . One is at the lower left hand side of the drum and you also have the two screws that fix the hot air channel ( going into the top of the boot gasket ) to the top area of the drum concrete weight. If either of these have come loose or broken , the vibration is exaggerated and this causes the top bracket to keep snapping
