Re: BOSCH WVF2000 dryer not drying
LaverdaBloke wrote:someone suggested there may be a reset button on the back.
No washer dryers do not have that feature. The fan motor may have seized up or the overheat thermostats tripped out? Whatever the case it will need careful investigation. Now these machines aren’t the easiest to sort out so if you want to lift the lid are poke about do please ensure your disconnect the machine from the power first? :zap:
If you would like a local independent engineer to call and sort it, then click the link below. 😉
