delta01 wrote:suspect control panel only two yrs old but heavy use .
Not a control panel on this model as its a Balay made anyway. More likely the motor brushes (first thing to change) check the motor wiring as the harness tends the chafe 😉 and finally the little module is usually trouble as well? 😉
