Bosch WVF2402GB/02 dryer fan motor not working
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WVF2402GB/02 dryer fan motor not working
  • #60386
    grazzamongrel
    Hi I have been to a Bosch WVF2402gb/02 today and the stat on dryer manifold had tripped so i reset it thinking that’s the end of it but when I tested appliance I noticed the dryer fan motor was not working. I checked to see if it had a supply to it but it didn’t but I see a capacitor in the circuit with it so was wondering if this could be the cause or if anybody else had an idea what the cause of no dryer fan motor action? I can only think
    That the dryer timer or control timer could be faulty but based on bosch reliability I am thinking that they are fine.
    Any help or advice is greatly appreciated due to cost of new fan motor assy I wouldnt want to order one if I dont need to. Many thanks Graham
    #341989
    Re: Bosch WVF2402GB/02 dryer fan motor not working
    Capacitor (172291) most likely I would think?
    #341990
    S1MON
    O/C dryer valve can cause this if the resistance of the fan is fine
    #341991
    grazzamongrel
    the valve seemed to work fine as every few minutes the drain pump came on and you could hear water getting pumped away but air not getting circulated due to fan not running
    #341992
    PINKY
    Duff fan i’d say. Fail quite often
    Pink!
