Bosch WVF240SGB Won’t agitate
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WVF240SGB Won’t agitate
  • #100933
    shabz
    The motor does not turn at all on the agitate part of the cycle however it will happily turn in any spin cycle, I have tried replacing the motor control board but no joy. Any ideas?
    #482746
    not a lot of info about this one
    cant find many pics of motor module components but judging by the ribbon connector its the switch at the top that decides what the motor is doing. looks a bit like an old style mechanical timer so i would expect a motor on the rear of it would activate contacts to tell module what to do. I would inspect the ribbon cable for damage and bad connections.
    cant see the top switch listed on Bosch and listed on connect as obsolete
    shabz
    Thanks for the reply, yes it’s the old type mechanical timer. Cable seems fine so I’ll try a new timer
