Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WVG30461GB/02. washer dryer.
- This topic has 7 replies, 6 voices, and was last updated 7 years, 7 months ago by
aqualectric.
August 15, 2018 at 11:51 am #94441
aqualectric
ParticipantBosch WVG30461GB/02 washer dryer. FD9604. Znr:- 400993.
Shut the door, press start, door lock clicks twice then nothing. No fault code – just the display showing the program details; cycle won’t start. Changed the interlock, no difference.
This interlock is the instantaneous type (pt no:- 00638259) that works with the fixed door peg with the square hole in it (no hook). I have had a fault with this type of peg and interlock in the past and never really solved it even after changing virtually all the interlock and door parts.
Anyone had this fault and what is the solution? Could it be a failed PCB? This machine is only just out of warranty and used by one person, so I have referred her back to Bosch in the first instance.In the meantime…… any ideas?
Thanks!!
Steve.
August 15, 2018 at 3:15 pm #457358timdowning
ParticipantRe: Bosch WVG30461GB/02. washer dryer.
Only that whenever I see washer dryer I think weird dryer element fault…
August 15, 2018 at 8:05 pm #457359aqualectric
timdowning wrote:Only that whenever I see washer dryer I think weird dryer element fault…
Please elaborate Tim…….. thought it was only Lux based washer dryers that had the stupid dryer heater issues…….. I’m intrigued…….. 😯
Thanks!
Steve.
August 28, 2018 at 12:06 pm #457360kram
Hi, did you resolve this issue ?
I have one doing exactly the same.
No fault codes – Main PCB at fault?
Cheers Mark.August 28, 2018 at 3:07 pm #457361murv
Just a thought, could the child lock be active?
Murv…
August 29, 2018 at 11:07 am #457362kram
Checked the child lock 1st thing. On this machine oddly the child lock is program specific so you need to check on the last program used (and all the others for good measure !). Door interlock is functioning.
Tried reset. Last fault code is E00. No fault codes flagging up either.
Cheers.
September 6, 2018 at 11:28 pm #457363nomadPaul
Power/control module at rear most probably.
November 19, 2018 at 9:08 am #457364Steven
ParticipantHI, I have had three with the same fault, i referred the first one back to Bosch which was three months out of warranty and they covered it for him, it was main board fault.
Maybe they have an issue with it normally they won’t cover one day over let a lone three months!Steven
