Apparently this trips the fuse box every time they use the dryer, i know from previous visits the machine is in a really awkward place to work on so how difficult is the dryer element to change on these?
Access to the fan and heater box should be straightforward through the top, if I recall, with just the usual risk of the heater bracket securing screw being seized in the casting. You might need to move the control panel and/or dispenser out of the way, but I don’t think so. Access to condenser requires the full back panel to be removed, so potentially tricky and time consuming if access is limited.
