Bosch WVT 1260 W/Dryer – Marks on clothes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WVT 1260 W/Dryer – Marks on clothes
  • #18489
    aeronaut
    This is a brand new machine which is leaving a soap powder residue both on the clothes and on the bottom of the door seal.
    The machine is not being overloaded and water pressure is not a problem.
    Any other thoughts? The missus is not best pleased at the moment 👿 and we dont really want to switch to liquid if at all possible.
    #179202
    Re: Bosch WVT 1260 W/Dryer – Marks on clothes
    aeronaut wrote:This is a brand new machine which is leaving a soap powder residue both on the clothes and on the bottom of the door seal.
    Lots of options here, Is the detergent placed on the clothing or in the dispenser? Is the correct programme being selected? Has the ‘economy’ button been selected? Running it without clothing, how much water enters the drum during wash? Does it drain fast enough…….?
    #179203
    aeronaut
    Powder in the dispenser, 40 degree wash cycle, economy cycle not selected.
    I’ll check out the rest..
    #179204
    aeronaut
    it fills almost a third of the way up the door
    #179205
    Hmmmmm! Seems the machine checks out then and the mystery unsolved from what you say, that’s very odd you still get marks on clothes then 😕
    I also would’nt recommend liquid detergent but to put the powder in the dispenser rather than in the drum (especially as you have good water pressure – that should take away the powder nicely!)
    As it is brand new, why got give the problem for Bosch to solve eh? 💡
    #179206
    Overdosing? Other than over loading it’s about the only other thing that can cause it, unless it’s a cheapo detergent that isn’t disolving properly.
    I’d seriously doubt it was anything to do with the appliance.
    superfix
    Eliminate all other factors first though, as no fault with machine = chargeable job.
    #179208
    firehorse
    I was thinking about buying one of these.
    Did you ever get this soap powder residue sorted out???
    Alan
