Bosch WVT1260
  • #75649
    sdl
    Does anyone know how to get into the test mode on a Bosch WVT1260
    Washer/Dryer. I have tried all the known Bosch test modes without success.
    Pete
    #395729
    Re: Bosch WVT1260
    I’ve no clue Pete but have to ask you why? What is the problem with the machine?
    #395730
    sdl
    Re: Bosch WVT1260
    Hello martin,
    After servicing a Bosch Washing machine I usually go through all the test modes to check that all is OK. I can check the motor, heater, inlet valves and pump.
    Just wanted to know if anyone knows how to get into the service mode of this W/D.
    Pete
    #395731
    nomadPaul
    Re: Bosch WVT1260
    It should be :-
    Programme selector to off
    Press start button for at least 3 secs and turn selector switch to easy care 40*c . This will put you in to the single component test programme.
