Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WVT1260GB/01
- This topic has 1 reply, 2 voices, and was last updated 16 years, 5 months ago by
geoffmackay.
November 11, 2009 at 7:38 pm #50076
geoffmackay
ParticipantCalling all Bosch experts. This washer drier refuses to dry . Checked fan, running at correct speed. Checked stats toc and element ok. Heater box gets hot but clothes are stone cold after 10 mins.
I was thinking blocked condenser but surley clothes have to heat up to steam first. No blockage in heater box or spout into drum. Condenser looks clean under fan. Machine is flushing and pumping ok.
Wasa thinking along the lines of Zanussi washer drier if condenser blocked clothes are hot but wet?
Any ideas guys?Geoff
November 12, 2009 at 12:11 am #303227lee8
ParticipantRe: Bosch WVT1260GB/01
Have you checked there is water entering the little chamber.
The Element should have Resistance: 34.5- 36.5Ω
The NTC operating range is between –5 °C and 103 °C.
The programme continues cold in the event of an interruption or a
short- circuit. The test programme displays “NTC short circuit” or “NTC
interruption”.Temperature in °C Resistance in kΩ
10 °C 8.5–10.6
20 °C 5.4–6.5
30 °C 3.5–4.3
40 °C 2.3–2.9
50 °C 1.5–1.9
60 °C 1.1–1.3
66 °C 0.9–1.1
86 °C 0.45–0.55If not go into test program, follow these instructions
1. Selecting the test program
Observe correct method for setting program selector!
Activate
test program:
Set program selector to OFF position
Press START button for at least 3s
There while set program selector to a test program:
-Program Easy Care 40°
-> Single component test (see 2.)
-Program Cotton/Coloureds 90° ⊕
-> Automatically test procedure (see 3.)
-Program Cotton/Coloureds 40° (Chinese variant)
Program Cotton/Coloureds 60° (European variant)
-> Test and demo program LCD-display (see 5.)
Display
If fault is detected, Fxx / Exx* is flashing
Error is displayed only one time
Icons rinsing, sun and spinning illuminate,
no residual term, display active
no residual term
display active
Start
test program:
Press START button at:
– Single component test (see 2.)
test program starts automatically at:
– Automatically test procedure (see 3.)
– Test and demo program LCD-display (see 5.)
Abort
test program:
Adjust program selector or press START button at:
– Automatic test sequence (see 3.)
Switch OFF appliance at:
– Test and demo program LCD-display (see 5.) -
