Re: Bosch WVT1260GB dryer overheating
I didn’t read your question fully- yes could be blocked but more likely in the heating element housing somewhere but much more likely as you have alluded to the fan motor
I have had both problems, I found my blockage around the fan turbine inside the housing just release the nuts and bolts holding it down to drum
(It’s easier to do it than explain it) You will see how to split to gain access to elements and turbine
gotta go Tablet battery less than 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
