Bosch WVT1260GB Washer-Dryer – Not Drying…
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WVT1260GB Washer-Dryer – Not Drying…
  • #65944
    Sparky67
    Hi there,
    Our WVT1260GB has stopped drying. I’ve had the lid off, the heater measures 35 Ohms, the 3 sensors on the heater box lid all show s/c with one lead off. But I’m not seeing 230VAC at the heater connections. I’m now stuck… 😕 Where should I be looking next please ?
    Re: Bosch WVT1260GB Washer-Dryer – Not Drying…
    Water inlet valve!
    #362445
    Sparky67
    Thanks Martin. Just checked the water inlet valve and there’s water flowing through the outlet pipe and through the little plastic container fixed to the rear panel and on to the condensing part.
    I am measuring 230V at all the sensor terminals and at both heater element terminals against chassis, but nothing between the heater terminals. Now I’m really confused… How does the heater pick up its neutral return ?
    Sparky67 wrote:How does the heater pick up its neutral return ?
    I believe it is switched on the neutral side at the main circuit board. 🙁
    #362447
    Sparky67
    …and there was I hoping it was something a bit more straightforward !! Is it a relay switch – or via a triac or similar – do you know ? And are spare cct boards available ?
    #362448
    Sparky67
    ….found the relays and removed/checked/cleaned them all. Two of them are not getting 12V to the coils – the voltage drive to the transistor array to activate those relays is also missing at the edge connector to the rear of the board. That looks like a main control board issue – unless the voltage is inhibited by air-flow or water level sensors or anything which need the case removing to access ? Help !!
    #362449
    Re: Re: Bosch WVT1260GB Washer-Dryer – Not Drying…
    Sparky67 wrote:….That looks like a main control board issue –
    Well I never……. 😉
    #362450
    Sparky67
    Took the control board out to see if there was anything obvious, which there wasn’t… Put it all back together again – and the dryer now works :rolls: Just hoping it was a loose connector and not an intermittent fault on the board 😕 Thanks for the pointers.
