Bosch WVT1260GB Washer Dryer stops at 1 minute
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WVT1260GB Washer Dryer stops at 1 minute
  • #87394
    derekjh
    Bosch WVT1260GB Washer Dryer runs through various programmes OK but stops at 1 minute, doesn’t beep and door wont open. Door can still not be opened even after power switched off. During programme drum fills, rotates, heats, empties and spins but then stops at 1 minute. All seems to be working normally until this point. What could the problem be?
    #434711
    Re: Bosch WVT1260GB Washer Dryer stops at 1 minute
    most common cause is heater earth fault but there are others
    dave
    #434712
    derekjh
    Thanks Dave
    I have checked the insulation resistance of both heater elements and neither are showing any leakage to earth. Any other. Suggestions?
    Regards
    Derek
    #434713
    sometimes they don’t and still it causes it. try disconnecting the heater and tape up wires as a test. it will go through a programme just takes longer as it waits to heat and then give up
    did you search forum and see this
    http://www.ukwhitegoods.co.uk/help/fix- … t-1-minute
