Bosch WVT12840
  • #39940
    jordanccfc
    Hello All,
    I need your help… our bosch washer dryer has a problem draining water out of the drum.
    the timer goes down however after a certain amount of water has been drained it always leaves the same amount in the drum,
    THEN ERROR MESSAGE ER06 APPEARS.
    Firstly does anyone know what this means , so i know where to look? we have just moved into this flat and have been left no manuals for any of our appliances.
    Secondly i have emptyied the filter.
    Your help would be greatly appreciated, as we go on holiday and we are trying everyhtning to get our clothes washed!.
    Jordan
    #264220
    gegsy
    Re: Bosch WVT12840
    Check where the empty hose goes to and make sure its not blocked or kinked.
    jordanccfc
    Re: Bosch WVT12840
    thanks for the quick reply…
    i will check that now, but if anyone else has any suggestions that would be great….
    #264222
    Re: Bosch WVT12840
    Hey i’ve got the same machine and am the same…i rent a flat and no one left me a manual!! Luckily I have a plumber for a boyfriend!!
    I caused it to do the same thing because I was overloading the machine. Make sure you only half fill it. Annoying I know but it’s the only way to stop it happening again.
    The only way to stop it is to pull away the bottom panel and empty the excess water…im not entirely sure what my boyfriend did but he drained water somehow.
    That was 4 months ago and it hasn’t happened since!
    Have you managed to figure out how to use the dryer settings on it? I can’t figure it out but i’m just trying to download a manual now…
