Bosch WVT12840GB/03
  • #53037
    rocker
    When on tumble dryer the temperature limited keep activing..can reset then runs for a drying cycle between 1 to 2 hrs works ok…customer tries to run another dryer cycle no heat..limiter O/C..I have removed rear fan vent housing ok..motor cir fan runs free and ok…still the same…dont know what to next..can anyone advise please, John
    #314156
    Re: Bosch WVT12840GB/03
    Have you run it with the door open to check the actual airflow? Failing that, operating thermostat or earth leakage on element?
    rocker
    Thanks Chris, will do the checks you suggest. John
