BOSCH WVTi 3240GB/02. FD 8410
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BOSCH WVTi 3240GB/02. FD 8410
  • #56281
    richardable
    called to this one, symtoms…choose any program.
    door locks, drain pump starts, drum rotates a couple of times, light for
    1400 spin speed flashes, door releases, machine stops. fault display E14.
    no info to hand, rang BOSCH TECHNICAL HELP, …E14 DRYER NTC FAULTY. check both and both test ok. but found a broken connection in the
    plastic push on connector on the stat by the dispenser drawer. made it good. now all ok.
    hope this helps.
    anyone got a BOSCH fault code list.
    thanks
    richard
    #326800
    Re: BOSCH WVTi 3240GB/02. FD 8410
    richardable wrote: anyone got a BOSCH fault code list.
    I guess you didn’t spot THIS in the KNOWN ERROR CODES then eh Richard? 😉
    I put ’em up, you note ’em down…fair deal or what? 8)
    #326801
    richardable
    martin
    thanks. 😳 😳
    richard
