Bosch WWF1401 drum noise
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WWF1401 drum noise
  • #81997
    Fishie
    I have recently changed the bearings/pump on my washer, and now on the fastest spin the drum is banging. I suspect the shock absorbers (all three springs are present) but would like a second opinion as they’re not cheap!
    #418377
    Re: Bosch WWF1401 drum noise
    I’ve never heard of a WWF1401 are you sure you got the ENr number correct? Is it a Bosch?
    #418378
    Fishie
    Hi Martin,
    thats the No on the front of the machine and the No Espares refers to.
    Regards
    Iain
    #418379
    Ah I think you may need Specsavers then as I can only find a Bosch WFF1401GB/01.
    To test the shock absorbers simply remove the lid and push down and release the drum. ( Much like testing car shocks by pushing on the wing) If it bounces back they’re duff and need replacing.
    #418380
    Fishie
    Thanks Martin, dyslexia I feel maybe the issue!!
