Hi Gents
have a bosch diswasher has a float in bottom of cavity not base machine fills then empties a bit out tops up then empties abit out then so on &so on the water indecator neon comes on no wash action empties completely when reset asked for
cheers alro
Re: BOSCHSGI45E16GB/23 FILLS THEN EMPTIES A LITTLE
Flow meter – water wheel containing a magnet is spun by the incoming water flow past a reed switch in the housing. Computer counts the resulting pulses and works out how much water is entering the machine.
If it doesn’t, flood protection operates fill, drain, fill, drain……
